ok, update on this, haven't had much of a chance to mess around with the car, seems to be raining all the time when I get the chance!!! It's supposed to be xxxxxx summer!
Can confirm the cam timing is defo right, and I've done the ignition timing exactly as stated in previous posts and was doing it right in the first place anyway.
I still can't get the needle to line up with the 10 deg notch!!!!!!!!!!!! It just doesn't make sense, when I'm rotating the distributor to adjust the ignition timing the sound of the engine changes, it sounds best somewhere in the middle and sounds about right but when I check the timing gun, the needle is to the left of the first notch
(TDC) rather than to the right of the TDC notch where the second 10Deg Notch is.
When i go to each extreme
(furthest clockwise and furthest anti-clockwise), the sound of the engine is not as good as it is somewhere in the middle so that tells me the distributor is in the right place it just needs a reference point to get the timing bang on, but this reference point isn't there as the needle doesn't line up witht the notches!
What I'd try to do before, and tried again, which is the logical thing to do I think, was remove the distributor and put it back in with the rotor arm adjusted accordingly so that the needle when setting the ignition timing can travel further right and closer to the 2nd 10deg notch, however when I do this the car just about starts as if the timing is out of range and doesn't stay running unless it's revved.
When I rev it to keep it running I can just about check the timing with the light and find the needle is now to the right of the TDC notch where it should be but the engine doesn;t run right as the timing is out.
This is what just doesn't make sense to me! So this is my problem still and I don't know how/why it would possibly happen!? What other factors are there that could affect this? Any ideas.
