I went to move the MR2, and the belts were squealing.
Switch off, get out, and there's smoke EVERYWHERE.
The sodding alternator has jammed.
marcnoonan wrote:
You'll also need to remove the downpipe to get the alternator out of the bay.That should be 2 12mm nuts on the mid support and 3 12 or 14mm bolts on the manifold/downpipe connection which you'll need a deep socket for and finally 2 bolts on the dowpipe/cat section.
Really simple job to do, as long as the bolts aren't all rusted solid.
Wanna sell me your dead one for£10 delivered?
RichardK wrote:
I was right onto that until the downpipe bit.Seriously? It looks like I could remove it from above.
I'm really not into taking the exhaust apart.
