you have well flooded your ignition system buy the sounds of things did you jetwash your engine by any chance, as said dry out leads, plugs, dizzy cap and all your multiplugs or give it a few days to dry out by itself may take a while though that way
hmmm not heard that before had my car well soaked but never had that before mines an n/a though, i suppose tubbys have different engine covers and may let more water into engine mind you in saying that dont engine lids have rain covers on them to help this
ok iv took the leads of and put wd40 down there and its just the same whats happening is its starts no probs and seems to tick over ok but when you start to move thers a noise from the engine like its just running on 3 cylinders and thers no boost and it wants to cut out altogether but it starts agian no problem
yea i done that first but there was no water down there. i think ill change the plugs any way .what plugs should i get and iv just orderd a new dizzy cap and rotar arm as they look a bit f@:>@
ok iv changed the dizy cap,rotar arm and spark plugs but my car still seems to be running on 3 cylinders can any one think of any thing else that would be making this happen
Ollie @ Skyinsurance wrote:If it is REV1/2 spec then I recommend you check the AFM. I had a similar problem with mine and it was the AFM flap stuck open.
yea its a rev2 and iv just bought a afm of a member on heer hope fully it should be heer next week ,im gona do a compression test tomorrow and see if any thing is wrong there. could it be a f?@: injector ?
