[Mk2] [Turbo] Knock Sensor
gurteen0
Post by gurteen0 »
[/b] Help !!!!
Exactly where is the Knock sensor located
Mine is gone and I've picked 1 up and I need to know where it is
any info much appreaciated
Thanx all :-k
Grajey
Re: [Mk2] [Turbo] Knock Sensor
Post by Grajey »
Here you go.
Top centre, just above the left core plug.
HTH
gurteen0
Post by gurteen0 »
Thanx matey
I'll have a go at it
Cheerz :thumleft: :thumleft: :thumleft:
karammander
Post by karammander »
make sure you torque the new one as per the bgb as a wrong torque setting could confuse the sensor.
cheers karam
Post by Martin F »
pretty sure its a 27mm socket you need but IIRC mole grips will suffice as its not highly torqued... :-k
Kubus
Post by Kubus »
whats the torque that should be used to put it back in ??
Grajey
Post by Grajey »
According to the BGB. 33ft lbs.
Return to “Electrical”
