Trying to narrow down an issue that has raised its head since the Clutch and flywheel were changed for new ones recently
Bit of background:
I've been getting a clunking sensation from the rear of the car as I pull away from a standstill with the car on some lock.
Once the car is moving a bit then the clunking goes away.
The car just went into my local garage to have the radiator replaced so I got them to have a check of things whilst they had it on the ramp as they suggested it could be a CV joint.
The guy from the garage took the car out for a drive also and he thought it could be LSD related but didnt know enough about this particular car to advise any further.
I dont know if the diff has been changed over the years for an aftermarket one but when the gearbox and drive shafts had been taken out of the car for the clutch change etc the garage did suggest that the Diff looked like it could be different from standard
Now here are my thoughts:
I was wondering, as was the chap in the garage if the wrong gearbox oil had gone back into the gearbox.
Another thought of mine is could the driveshafts be the problem? The garage said it all looks ok however they didnt know if the driveshafts had to be lined up in some way to make sure the LSD worked properly.
The reason i think its the lsd buy the way is the back nearside rear tyre seems to catch and release as you pull away.
Also you seem to notice the problem more when pulling away slowly whilst making the turn.
Anyway enough gasing, would people please make any sugestions they might have on this.
Much appreciated
Tom
