i've just got hold of a copy one from another member on here and before i bought it he said he wasn't happy with the fit when the body shop put it on, so with that in i mind i knew it wasn't gonna be plain sailing.
however i think its luck of the draw to exactly how bad the fit is, my advice would be to be well prepared to some bodging action to get a good fit, either by yourself or at a cost as its a nausiating job!!!!!!!!!!!!!!!
if you plan on sending it to someone else to make fit then i would seriously consider trying to source an original for a guarenteed fit, in the long run i couldn't see it working out too much more expensive, but then i dont know how much an original is.
steve
