[Mk2] [Turbo] A bit of help needed
Leezon
Post by Leezon »
Hey guys, ive just bought Carly's MR2 Turbo and love it! :D
Only problem is i cant get the rear boot to unlock with the key she has given me, it just wont turn. Any ideas?
Also the ariel wont go down, even if i do turn the radio off before the ignition.
Leon.
Re: [Mk2] [Turbo] A bit of help needed
Post by Leon. »
Why don't you ask her about the key?
So the ariel is always up? Is it connected to the back of the head unit?
Leezon
Post by Leezon »
I have asked her about the key and she says she never used it on the boot, only ever used the release pulley.
Im not sure about it being connected to the head unit. When we went for the test drive it was down and she turned the head unit on and the ariel came up.. but its not gone down again.
Leon.
Post by Leon. »
Key: try lots of WD40, and lots of wiggling, it might work free.
Ariel: then the motor might be knackered or power intermittent/faulty.
C50
Post by C50 »
I hear some people have wired a manual switch to extend and retract the ariel..
Tiamat
Post by Tiamat »
There are two keys for the MR2s, a drivers key and a passenger key.
The driver's key unlocks everything, doors, boot and glove compartment.
The passenger key will not unlock the glove or the boot.
Don't keep trying it in the lock or it will bend and break.
If you got 2 keys with it, try the other key.
Leezon
Post by Leezon »
I was only given 1 key with it. I have been trying it again today and havent gotten anywhere..
Any ideas!? :(
Leon.
Post by Leon. »
Tiamat wrote:There are two keys for the MR2s, a drivers key and a passenger key.
Oh :-k
carlymr2
Post by carlymr2 »
Sorry i had no idea about the other key, i was only given 1 key when i bought the car. I did ask Rhys is there was a spare and he said there wasnt. You could drop him a PM and double check?? As for the aerial it has always worked fine for me..........must need a womens touch :shock: lol
ChrisW
Post by ChrisW »
My brother had the same problem with his boot lock. In the end he bought a new lock cylinder from Toyota (about £25) and posted it to 3S with a spare key to get them matched up.
iblis
Post by iblis »
But only the driver's key will start the car. Seeing as he has only one key and can drive the car, I guess this is not the issue :wink:
I'd say the bootlid was replaced at some point, so it has a different key, which may not have come with the lid if it came from a breakers.
Tiamat
Post by Tiamat »
No. The passenger key will also start the car.
iblis
Post by iblis »
You sure? Not trying to be a smart ass, just curious. My parents have an avensis and there's a grey key which only unlocks the doors. Doesn't start it or open the glove box. Maybe it's a valet key or something :-k
Tiamat
Post by Tiamat »
Yes, thats a valet key. The passenger key is there so they can steal your car and smash open the bot and glovebox at their leisure, rather then unlocking it! I use my passenger key for the MK1 as its less worn and starts the car easier, without rattling the key around, but it means I have to pop the boot from inside.
iblis
Post by iblis »
Tiamat wrote:Yes, thats a valet key. The passenger key is there so they can steal your car and smash open the bot and glovebox at their leisure, rather then unlocking it! I use my passenger key for the MK1 as its less worn and starts the car easier, without rattling the key around, but it means I have to pop the boot from inside.
I always presumed they were the same thing, something new learned :thumleft:
Leezon
Post by Leezon »
So what do you suggest i do then?
Leon.
Post by Leon. »
This:
ChrisW wrote:My brother had the same problem with his boot lock. In the end he bought a new lock cylinder from Toyota (about £25) and posted it to 3S with a spare key to get them matched up.
Tiamat
Post by Tiamat »
Leeroy wrote:This:
Or see if someone like Rogue or 3S are breaking one and can provide you with complete locks and keys and replace them that way.
Leon.
Post by Leon. »
Tiamat wrote:Or see if someone like Rogue or 3S are breaking one and can provide you with complete locks and keys and replace them that way.
Even better :thumleft:
Could try the breakers on here too, and a guy called MR2-Ben in affiliates...
jmachling
Post by jmachling »
Leezon wrote:Also the ariel wont go down
That's just wrong subjecting the Little Mermaid to abuse like that! :twisted:
I think you mean aerial :lol:
