[Mk2] [Turbo] What way does accuator go
Does anyone know which way to adjust the Forge accutators to turn down the boost.
At the minute my 2 is boosting to well over 1.2 bar!!
Re: [Mk2] [Turbo] What way does accuator go
Hi there, you will need to remove the clip off the wategate and lift the arm off.
then effectively lengthen the rod by unscrewing the rod for a few turns, its a bit trial an error really until you get the wastegate to open at the right boost pressure.
