[Mk2] [Turbo] Im stumped, car starts but then cuts out, read on...
paul port
Re: [Mk2] [Turbo] Im stumped, car starts but then cuts out, read on...
Post by paul port »
Things to check now are:
1. What's the voltage output from the AFM when this is happening?
2. Unplug the cold start injector / check if it's open continuously
3. From cold, start engine and release rad cap - any bubbling? let's just be sure this white smoke isn't water and the smell is just because the water quenched the spark.
The BGB (actually the blue 3sGTE engine supplement) will have a step-by-step fault find procedure for this scenario, suggest running through it
paul
Adam J
Post by Adam J »
Cold start would not make it run that rich. I think it is more like something along the ecu side that is making the injectors open fully on idle, possibly a break between afm and ecu? Use the bgb to check the vaultages at the pins.
Reece
Post by Reece »
All fixed so Im told, it was a faulty wire to the AFM, sorry cant be mroe technical but we ll ermmm Im not see here for outcome.... http://www.imoc.co.uk/forums/viewtopic.php?t=66249
