[Mk2] [Turbo] nuclear explotions on quick gear changes....?
jimGTS
Post by jimGTS »
when going for a run, occasionally, if im giving it proper beans and changing gears really quickly and plant the foot on the loud pedal, sometimes i get a massive, quite violent explotion/pop/bang from the exhaust.....
not just your average bang and pop from such a setup like downpipe/free flowing exhaust....
but realyl quite a shock wave type explotion.
just wondered if anyone else gets this?
its quite worrying when it happens! and ONLY ever happens on extreme gear changes...
jimGTS
Re: [Mk2] [Turbo] nuclear explotions on quick gear changes....?
Post by jimGTS »
anyone?
Rory
Post by Rory »
What ECU you running now Jim? You got your apexi on yet or are you still running rev3 ecu conversion?
My MR2 for sale! Check out the for sale section
jimGTS
Post by jimGTS »
yep rev3 ecu...
mapping soon thankfully....1-2months...
if all goes well at rogue for the go ahead, leak down tests/compression etc etc....
RyanRs
Post by RyanRs »
probally just a little bit of excessive over fueling, especially if it isnt yet setup, as you say its going in for mapping.
alexwainwright
Post by alexwainwright »
I'll put forward my theory:
Pretty much all MR2's seem to dump quite a lot of fuel into the engine during a gear change when driving 'hard' - usually giving a puff of black smoke, but occasionally flames. I THINK this extra fuel is thrown in during the instant you come off boost. If you're changing quickly, I guess your sending extremely hot gases straight down the exhaust right behind the unburned fuel from the gearchange, possibly igniting it earlier than usual (i.e. when you just get some flames from the exhaust).
Or, I could just be a bit drunk...
