![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
I have 2 water injection kit's kicking aboot now would it be pointless to use water injection with a charge cooler
![Very Happy :D](./images/smilies/icon_biggrin.gif)
xxxx wrote:why would it be pointless to run a chargecooler and water injection?
Tim
xxxx
V8Killer wrote:If you have have too much water injecting at high rpm you'll lose power(which makes sense if you look into the technicalities of WI).
Whereas if you can reduce the flow rate at higher rpm you'll gain more power.
A mappable WI system gained me about 10% extra power(30BHP).
DaveART wrote:
lol, yes, obviously..
.who the heck is going to use a fixed amount of WI
DaveART wrote:.
.but to repeat, if you charge temps are low enough pre WI, then any amount of water, low or high will not see any gains.
RichardPON wrote:Water injection is not about gaining extra power- it's about REGAINING lost power due to excessively high ACTs.
RichardPON wrote:One of the most over-used mods, and so often fitted when not required.
RichardPON wrote:Why would you want to be puting water into the combusion chamber, no matter how fine the particles, when it's not required.
RichardPON wrote:Show me some full load ACT v ambient v boost pressure graphs and then decide if it's required.
RichardPON wrote:WI should be used as a last resort beyong all explored avenues of cooling the charge..
allan welsh wrote:didn't wwII fighter aircraft use water injection to control the burn rate even when flying at 20k ft? Enabled the fuel to all get burned in more repeatable repeatable fashion lol
