Thing is i'm now needing some help.
Simon
Goldy wrote:Just to clarify i've bought a supercharger to put onto my mk2![]()
(not a mk1 supercharger)
MartG wrote:The other( mad
) idea I had was to bin the 3S-GE and drop a Vauxhall C20LET in
( same as in my Calibra
- cheaper to get bits for than a 3S-GTE and can easily be modded to give 300+bhp.
Added advantage is the matching F28 six speed gearbox
MartG wrote:Hmmmm..
.XE, with LET internals to lower the CR.
.supercharger.
C20 LET is an alright engine
its not as well designed as the 3SGTE
the engine is a bu88er to work on
it has some crazy bends on the intake/ throttle body
leaks oil everywhere
and is always running badly
Peter Gidden - sbITs wrote:C20 LET is an alright engine
Yea as in it goes like stink when it works![]()
Back on topic.
Help is still needed/ appreciated.
and i've put website up so I can keep an online diary if anyone cares..
http://goldy.biz
Lauren wrote:Simon,
as you are in the manchester area i'd recommend JP Exhausts(jpexhausts.co.uk) based in Macclesfield for making up your hard pipes to intercooler/inlet etc.
Good prices and bespoke quality.
Stephenj wrote:you could use a chargecooler for the ST165 which is nice n small+ you wouldn't need too much pipe work, in fact you could use any celica charge/intercooler but the 165 one is gonna leave you the most room in the bay.
