Oil cooler kits ....
Bender Unit
Re: Oil cooler kits ....
Post by Bender Unit »
There is some special stuff called Firebraid (or somthing like that) which is a fiberglass jacket for pipes - comes it quite dear though. I will get on the case! :D
3S Service Centre
Post by 3S Service Centre »
=D>
Owen @ Kent Car Craft
Post by Owen @ Kent Car Craft »
If anyone here including you Jamse,that can produce an oil filter relocation kit with cooling sandwich plate i'm jumping at the chance guys!
For a rev2 mind!
matt_mr2t
Post by matt_mr2t »
A) at what point of tuning is an oil cooler needed.
B) what benefits does it have?
I personally think its not a point of tune and a state of modification,
but the usage of the car that would warrant an oil cooler.
If the car is regularly used at trackdays/the strip i think its a good idea.
Having an oil cooler regulates the oil temperature of the oil circulating the system in the engine.The hotter it gets,the thinners it gets,losing its viscosity qualities.
If you look under the engine hood of a rev2,you'll see why i want to relocate the filter too!!
Andy F
Post by Andy F »
Not sure if these are any good James, if you need better picys let me know.........its a rev2 relocator kit.
Built by YVS Performance
Every car that leaves runs 2 bar+
matt_mr2t
Post by matt_mr2t »
Any one see the Silver R33 at Engine Advantages?
The cooler on that thing was the size of a large intercooler!
Hey Andy,that one looks pretty good,
where did you get it?
Andy F
Post by Andy F »
Elmo Owen wrote:Hey Andy,that one looks pretty good,
I got it from www.hpmotoring.com
it had a oil cooler with it but its not thermostatic, so i just used the relocator 8-[
Bender Unit
Hi Andy,
Thats was my plan for the relocation, just to check have you protected your rubber hosing coming from the take off? I am just concerned about heat issues.
Elmo,
I will try and get 3 kits made, 1 just to relocate the filter on the Rev1/2 engine and then oil cooler kits for both engines.
James
mikewright
Post by mikewright »
Nice one james - as i have been pestering fonzy for exactly this sort of thing due to a downpipe clearance issue the kit could not have come at a better time =D> \:D/
User avatar
Lauren
Post by Lauren »
Doesn't the MK2 have an oil cooler as stock?
The Mk1 NA does (was not fitted on teh SC or JDM cars though). Has a water/oil cooler.
Bender Unit
Yes it does, a tiny one located under the manifold which isnt the best place for it and its tiny. Fine for road use but maybe not on track?
An external cooler will give enhanced cooling to help drop the oil temps if the oil goes beyond 75 degC - over hot oil means it breaks down, lubrication is lost and cooling properties are also lessened.
Also a big advantagte for the Rev1/2 lot is they can move the filter from the stupid place it has next to the downpipe.
James
Yas
Post by Yas »
I'll be in on this, just not right away, spent too much monies on the 2 in the last month #-o
Defo sound's interesting though. Nice 1 James :wink:
Yas :D
Rikki
Post by Rikki »
Could be up for this one
=D> =D>
Yep James,i'll be up for that,
Let me know when dude.
Owen
ENSMR2
Post by ENSMR2 »
Just whizzed through the rest of this.
James, it sounds like the oil is to be diverted to the oc at certain temps. Is this how it works as stock?
If not is this likely to effect oil pressure?
SFLee
Post by SFLee »
my oil always sit at 80 and 85 and 90 if booting it so is 75 abit low ?
TBDevelopments
Post by TBDevelopments »
i've had oil coolers instock for about 3 years, £240 delivered, everything you need but there was never any demand for them.
Just sold 3 of them to the states for cheap just to get shot of them as they've been there for the last 3 years without selling 1.
No-one ever shop around in the uk anymore ](*,)
Tim
xxxx
ENSMR2
Post by ENSMR2 »
Your site don't list anything mate. That might be why?
Sort it out Tim! :wink:
