My 400whp saga, 373whp after mapping.
- IMOC Moderator
Re: My 400whp saga, 373whp after mapping.
Ah that's reassuring then thanks!
Ryan S wrote:Actually had a message from another member suggesting this.A very very common issue at this power level so I'll get the pump wiring sorted too.
The whine drives me absolutely mental haha! It is non stop from the moment you turn on the ignition:( what power are you making and what injectors/rail?
I'm making around 360whp at around 1.9bar.
I also use Aquamist water methanol injection
- IMOC Moderator
you using a walbro on stock wiring? I'm hoping to get changed back to a regular return line this weekend.
I should be able to see consistency through AFR gauge.
That seems to swing about all over the place just now as per the erratic pressure.
- IMOC Moderator
My relay has been done away with
Ryan S wrote:you using a walbro on stock wiring? I'm hoping to get changed back to a regular return line this weekend.I should be able to see consistency through AFR gauge.
Yes i'm using with stock wiring.
I'm sure the constant feel to the fuel pump is your issues.
For everyone's infomation, my was fluctuating with my Link G4.
- IMOC Moderator
You reckon add the relay back in?
I'm on a link g3 but the pump wiring has nothing to do with that.
How did you solve the issue?
If you've bypassed the relay it should be running at a constant 12V, which is fine.
Verify that though with a multimeter though.
- IMOC Moderator
SonicSW20 wrote:If you've bypassed the relay it should be running at a constant 12V, which is fine.Verify that though with a multimeter though.
It was my mate Kris who did the wiring.
Ryan S wrote:SonicSW20 wrote:If you've bypassed the relay it should be running at a constant 12V, which is fine.Verify that though with a multimeter though.
It was my mate Kris who did the wiring.Relay is deffo bypassed as i spoke to him today.
You can here the pump speeding up and slowing down when i turn the steering.
That's how much of a swing there is either in pressure and or voltage.
blip the throttle and pump picks up.
Slows down again on idle
(which is most likely normal) but when i turn the steering it slows right down.
Chris at Dynatune says he was getting pressure spikes at idle too.
So not just inconsistent at the top end.
We are gonna re-do the wiring to the pump.
It should not slow at idle if you've bypassed the relay.
The stock MR2 electrical system in good condition should have no problem providing a decent, steady output at idle.
- IMOC Moderator
Yeah i didn't think that was right either.
It also drops when the lights are turned on.
Basically anytime i use something with power you can hear the pump slow down.
Kris mentioned taking a feed from the the passenger side footwell.
Generally beefing up the wires to it.
- IMOC Moderator
https://www.dropbox.com/s/f52s3spzag4de ... o.MOV?dl=0
Here's a video clip.
The pump is louder than my bloody engine!
Do you think it sounds like this;
https://www.instagram.com/p/BujLg3gFvn8 ... 7na8jgh461
You'll have to scroll over to the video.
That was my walbro 255.
She was relatively quiet when first fitted.
And I ensured it was legit using walbros own guide.
She got louder and louder.
I started getting misfires/car jerking.
Car soon became undriveable after fault finding saw me replace all ignition components.
Had the timing chain off/back on
(exhaust cam was one tooth out).
And ECU recapped.
Long and short of it the tank was rusty causing the pump to block and unblock constantly.
- IMOC Moderator
Yeah sounds the same, I did see your tank.
My fuel is crystal clear so I don't think it's a bad tank.
I hope not anyway!
Ryan S wrote:Yeah sounds the same, I did see your tank.My fuel is crystal clear so I don't think it's a bad tank.
I hope not anyway!
Sounds like your all good then.
How's the car been driving? Any videos of you going for it?
- IMOC Moderator
It's driving so well, Docile about town but an total monster when you want it to be.
No vids yet but I'll be at the drag strip
(Crail) on Sunday this week so I'll get the GoPro hooked up
Ryan S wrote:It's driving so well, Docile about town but an total monster when you want it to be.No vids yet but I'll be at the drag strip
awesome dude.
look forward to the videos.
- IMOC Moderator
It's different, The powerband is shifted up the revs so its probably making a bit less power than stock under 4k then it just hits all at once.
It's a lot going on at 1 time.
Had a wee play with a 500bhp subaru and he couldn't pull away.
It's intense
It's intense
Ryan S wrote:It's different, The powerband is shifted up the revs so its probably making a bit less power than stock under 4k then it just hits all at once.It's a lot going on at 1 time.
It's intense
be interesting to see a race from a set of lights.
- IMOC Moderator
It would absolutely obliterate a stock mr2, Despite having slightly lower power under 4k you launch it at about that revs.
So you're under 4k for no time at all.
0-60 is way under the 5 second mark.
Very very low 4s
ð³ 0-100 is about 7 seconds.
