markstevieandmads wrote:Id replace the ignitor.
Also if its a rev 2 turbo then check ecu for leaking caps
Draven wrote:Leaking caps can cause any number of different issues.
markstevieandmads wrote:Unfortuantely its not just the caps that cause the issues.
They leak and corrode the tracks so 9/10 you will have to repair tracks too.
chrisE wrote:Just saw your wanted posts for the igniter(ignition module) then came across this so wanted to try and help.
Are you recirculating the bov or is it dumping to atmos?You don't appear to mention this anywhere.
Black plugs mean it's running rich
(sorry if you know this), so I'm wondering if the bov is leaking metered air.
Check if bov is recirculating and check the valve is working ok(ie.
not leaking under boost), and you cleaned the ignitor/coil bracket of any corrosion
(it's a ground point).
What does your boost gauge read on idle and on boost?Have you tried setting the actuator to wastegate pressure eg.
capping the actuator and turbo ports and disabling the boost controller?
This will prove if there's a leak.
If all else fails, I have a used& tested ignition module from my rev3 turbo you can have.
Regards,
Chris
rossonza wrote:Videos of the issue
https://youtu.be/5zbWj9KdZow
https://youtu.be/7FckbR_tQrM
Both videos I'm holding foot flat to floor.
chrisE wrote:rossonza wrote:Videos of the issue
Looks like you've got overboost going on there.![]()
Check the 6mm hose going from the turbo to the actuator to make sure it's not split.
Check the rearward-facing actuator hose going to the TVSV and check your TVSV is still connected to the ECU
(blue plug on the TVSV, under the intake manifold).
SonicSW20 wrote:Have you checked:
* ignition timing
* distributor itself
- cam position signal comes from the distributor, so damaged wiring, oil leaks etc here will make it run like xxxx.
* TPS calibration
* AFM
* fuelling
/ fuel pressure
* mechanical timing
Have you checked for codes since the last bits of work were done?
