Sorry only just got back in from Cardiff.
Yes it's really called an ISC.
To check this electrically, with the plug removed, you really need to check the resistance between the middle pin on the ISC body and each of the two outer pins.
This should be around 19
- 23 ohms.
I wouldn't worry too much about the voltage
But having re-read your original post, I missed the photo of the pipe you removed.
It's a while since I had an NA, but looking at an old photo of my NA engine bay it looks as though that is the pipe to the VSV or the idle up valve I was talking about.
I suggest you first try disconnecting the plug to this to see if that sorts out your fluctuating idle speed.
If it does, that suggests something is forcing it to open and close, or the valve is faulty.
But if your idle has only been fluctuating since you remove your aircon rad, it's possible that this is the issue, and there may be a sensor somewhere that is now confused resulting in the VSV opening and closing> That's just a guess as I've never tried removing AC, I like my home comforts far too much.
If however you suspect the VSV is faulty, there is one easy check you can make.
With the plug disconnected try blowing into the outboard pipe on the valve
(the one directly below the electrical socket) and check that no air is coming out of the other pipe.
IE the valve is fully closed when power is off.
If air is still leaking out of the second pipe, the valve is probably faulty.
If it's not the aircon rad removal and the VSV is operating correctly, I'm starting to run out of ideas.
But from what you've said, the VSV is definitely worth checking.
Paul
