I am away at the moment so, can't get to the car.
Does anyone know the innner diameter of water neck hose.
Water neck hose inner diameter
Re: Water neck hose inner diameter
not got the hose to hand but have a water neck, the metal output to the filler is 26mm.
Cheers bud
I am man hoping its same size for the tubing other end
I'm working on the car over the weekend so I'll find the hose I took off and report back.
Fairly sure it's a single size, it's doesn't reduce. The replacement silicone hose was the same size both ends.
found the original from my car.. the metal side from the water tree is 26mm, like posted before.
The silicone hose on mine is only 24mm ID and it's fitted to the plastic filler end. So 24mm ID fits and works.
Cheers bud
