I cooked the engine and blew the HG.
I took the head off, stripped it down and got it skimmed 12 thou.
Put the engine back together
I have double checked the static timing and is 100% bang on.
I can smell petrol after cranking.
I have checked for spark on a couple of cylinders and I get a spark but how good it is i'm not sure.
100 ish psi compression across all cylinders
No engine codes but oil light flashes not the engine light
Leads including king meter out in spec
Coil pack meters out in spec
Distributor meters out in spec and air gap gauges in spec.
When cranking if i put WOT then it nearly half fires a little but no real catching or coughing.
Initially I thought the injectors weren't firing but I now think they are as I can smell fuel and the top of a cylinder was wet looking thro the plug hole.
Is there anything I can meter at the ecu to see if the distributor is getting the correct signal from the dizzy? And to see if the injectors are getting a fire signal?
What else might the heat have damaged??
Or maybe I should just get a v6 for conversion.
