Nothings working.
Any recommendations?
Ross.
Gazza_DJ wrote:Heating and cooling cycles, penetrating fluid, and an impact gun that has some balls.Your average battery powered one won't cut it.
If it's properly corroded then you need to carefully cut the nut off and hope the threads underneath are OK.
pbmr2 wrote:Even when they are in good condition these nuts are fairly tight!
Gazza_DJ wrote:Wow, those look nice.What are they made from, and how much were they?
