whilst my cars having its engine swapped i was going to replace the clutch release bearing.
Any shops in the UK have it for under £40? TCBParts have it online for ~£22 but unfortunately out of stock.
Ross.
[Mk2] [Turbo] clutch release bearing
Re: [Mk2] [Turbo] clutch release bearing
Why not replace with a whole clutch kit? Bit more expensive but at least you know the whole clutch assembly has been replaced?
This guy has them. https://www.gt4-play.co.uk/shop/
markstevieandmads wrote:Why not replace with a whole clutch kit? Bit more expensive but at least you know the whole clutch assembly has been replaced?
This , it's common practice and sense to do this as it could save so much money in the event the clutch does slip in the future.
My car had it's gearbox out recently and the previous owner swapped the clutch and flywheel because when it does go it's an 11 hour job and money saved in the long term, (wasn't for him incidently) but for me it's great news
thanks guys, the car had a recent stock clutch fitted about 1000 miles before it was dumped in a field (so ive been told). ive asked my engine swap guy to take a look at the clutch plates and advise though first. either way i wanted to sort the clutch release bearing out
blogsy wrote:This guy has them. https://www.gt4-play.co.uk/shop/
price is ok, but £12 postage for a bearing? they just lost my business
Get an OEM one. Pretty much all the aftermarket ones are junk.
Gazza_DJ wrote:Get an OEM one. Pretty much all the aftermarket ones are junk.
yeah thats what im after mate
How much are they from Toyota.
