there is the no tools way of doing it.put the nut back on a couple of turns, put the aftermarket wheel back on firmly.
put the driver's seat back and go ape-poop trying to pull it off.
The nut stops it hitting you in the face.
The other way is to use a bearing/hub puller.![]()
