Had the dash plastics off and stereo out, found and fixed a broken wire which cured the stereo crackle, clipped the cig lighter connection back on and tidied the wiring above the pedals and cable tied them neatly out of the way.
Also mounted the turbo timer below the steering column
I also removed the volt and boost gauge screen which was mounted inside the clock recess and ran it into the gloveboxalong with the control joystick.
Had a quick wipe down of plastic and put everything back to together for now.
![Image](http://imagizer.imageshack.us/v2/xq90/922/t4lhZL.jpg)
![Image](http://imagizer.imageshack.us/v2/xq90/922/2LIPl3.jpg)
![Image](http://imagizer.imageshack.us/v2/xq90/924/MNV5jt.jpg)
![Image](http://imagizer.imageshack.us/v2/xq90/922/wRe3UJ.jpg)
