Ross.
ashley wrote:What revision engine do you have?
ashley wrote:I've just removed this from my 5S engine, which would be a bolt on for you:
- Mocal sandwich plate with side feed entrance/ exit take off plate
(bolts onto block)
- 2 x AN10 fittings for take off plate
- 2 x AN10 stainless braided lines with straight hose ends one end, and 90 dgree fittings other end
- Mocal remote oil filter plate
- 2 x AN10 fittings for remote oil plate
- AN10 one way valve to prevent oil drain back from filter when engine off
You'd have to start using slightly larger diameter filters- the Camry v6 ones are a direct fit.
I've got some pictures of it installed, and can take some of all the fittings for you if you are interested..
.or I could give you all the part references if you want to replicate it yourself brand new
Not sure what I'd ask for the kit, I'd need to look at what I paid.
.but it's an option for you.
