4AGZE Conversion
Re: 4AGZE Conversion
In regards to the air con compressor
- does it just un-bolt or does it have anything to do with the alternator bracket?
- Lauren
- IMOC Committee
It's on the other side of the engine to the alternator, so I'm sure they are totally separate.![](./images/smilies/spacer.gif)
2020 GR Yaris
- Circuit Pack ![lover :lover:](./images/smilies/jef_icon_lover.gif)
Same side on the MR2
'ZE.![](./images/smilies/spacer.gif)
- Lauren
- IMOC Committee
Yeah, I did wonder that! Would make sense with the SC I guess!
I've got a 4AGZE in the shed, but it's the other end of my short garden.
I think you'll just have to have a look.
They may well be as I know on my AE the power steering and AC are on the same bracket.![](./images/smilies/spacer.gif)
2020 GR Yaris
Got it off.![](./images/smilies/spacer.gif)
Air con compressor and bracket weigh in at 6.4kg
- nice to shed some weight as easily as removing that.![](./images/smilies/spacer.gif)
Mine doesn't have the oil cooler hose inlet on the sump.![](./images/smilies/spacer.gif)
JDM's, including the S/C, don't have the oil heat exchanger setup.
You could retrofit I guess, but if you want to save weight I wouldn't bother.![](./images/smilies/spacer.gif)
Hi Jon,
I already have the oil cooler bolted on to my N/A so it'd just be a matter of getting some flexi hose and robbing the old parts off my current engine.![](./images/smilies/spacer.gif)
However I suffer from low pressure on my N/A so I'm not sure I want to re-use my existing cooler.![](./images/smilies/spacer.gif)
