Looking for some info, has anybody used this bolt and washer set from mr2ben? Having my cover resprayed so looking to replace them.
https://mr2-ben.co.uk/products/660
Also on the subject, would people advise me to change the seals/ gaskets for the cam cover even if they were only replaced about 2000-3000 miles ago when the engine was rebuilt?
Matt
[Mk2] [Turbo] Cam cover washers/ bolts
Re: [Mk2] [Turbo] Cam cover washers/ bolts
I used them and they were fine.
Thanks for the replies. I'll order that set then, clean up the mating face of existing sealant and install as per the maintenance manual.
You can buy bolts and rubber backed washers on ebay for less than half that price you realise? Just saying...
Got a link Ashley?
I can't see anything other than just rubber washers.
For example:
http://www.ebay.co.uk/itm/M6-x-19-Stain ... 0828739751
Sure with a bit of hunting you can find smaller pack sizes, and correct washer sizes....or even just buy rubber washers and use them under steel washers...
Thanks for that ashley, I'd already bought them though. Will look on ebay next time. Cheers
