think ill take the hub's off and use a press
since i'm doing that going to replace both front wheel bearings
more pics and stuff soon
Grazzy wrote:swapping the wheels studs on the front for extended ones.need to wait for a replacement bolt to turn up.
sheared one
think ill take the hub's off and use a press![]()
since i'm doing that going to replace both front wheel bearings& lower ball joints.
also give the arms a quick blast and spray.
more pics and stuff soon![]()
2mad wrote:Wicked ecu/ interested to see how you get on with it
Grazzy wrote:2mad wrote:Wicked ecu/ interested to see how you get on with it
The options in the software are sick, I dont think theres anything out there it cant manage that i can bolt onto the car.![]()
Also knocked up custom mounting plate.
