[Mk2] [Turbo] Possible loss of performance, Mk2 rev2 Turbo
TheCombover
Post by TheCombover »
Mainly been commuting to work and havnt really taken her for a blast in a while, but today I gave her the beans on the way back from work but when boost kicked in it didn't feel as fast?!
What could cause this?
Thanks,
Patrick
2mad
Re: [Mk2] [Turbo] Possible loss of performance, Mk2 rev2 Turbo
Post by 2mad »
Hi Patrick, a brief run down of your cars engine and mods would help with a diagnosis .. it could be a simple boost leak (are you boosting the same) to running in bad gas mode if its a rev1/2 ...
Kev.
TheCombover
My car is running a hybrid ct26 turbo, gutted cat, hks silent Highpower exhaust with cut out silencer, aftermarket intercooler, greddy OLED ebc, I always run it on shell v power.
Last time I checked both my gauge and ebc read 15.5 psi. I will double check that tonight.
I'll check this weekend for any boost leaks :thumleft:
markstevieandmads
Post by markstevieandmads »
Im finding my car is a bit sluggish at the mo but blamed it on the hot weather. Im running a greddy copy intercooler without the shroud so thought that could be it.
TheCombover
Never thought of that, it has been silly hot recently which is not ideal for us turbo people.
But is there anything i should maybe check? Just check hoses for leaks?
markstevieandmads
Id be turning that boost down to a bar (14.7 psi) unless u got better injectors and a steel head gasket.
TheCombover
Ahh maybe that was my mistake I have been running it between 15 and 16 psi ] ](*,) will turn it down see she's happier :thumleft:
TheCombover
Turned the boost down to 14psi and seems a lot happier! :thumleft:
2mad
Post by 2mad »
TheCombover wrote:Turned the boost down to 14psi and seems a lot happier! :thumleft:
Good to hear buddy ... it could be hot ambient temps plus turbo being stressed at 16psi (producing a hot charge) coursing low performance .. anyhoo glad its sorted :thumleft:
