Need a new sump for my P reg, if I take one off an I reg (stock) it should be the same right? (ordering from ebay so can't see).
Asking a stupid question because I've already been burnt once
Are all standard sumps the same on UK mk2s?
Re: Are all standard sumps the same on UK mk2s?
There's no such thing as an I reg
And rev1/2 sumps are completely different to rev3/4/5 as they're different engines really
JohnnyC wrote:There's no such thing as an I reg
Lowercase L.
androo007 wrote:JohnnyC wrote:There's no such thing as an I reg
Lowercase L.
Nope, he's definitely written uppercase i
yeah I meant L sorry! And mine is R not P. Guess I needed more coffee that day!
Looks like L is late 93/mid 94, rev2 is up until late 93. Could be either :-/
L reg is most likely rev3.
You'll also need it to be from a UK donor car as imports didn't have the hole for the oil level sensor.
(Most likely!) L reg JDM rev 3, L reg UKDM rev 2
Mr2 Ben sells new ones and will be able to double check
Which one you need
Which one you need
Too weird to live, to rare to die
