[FINALIZED] Carbon bonnet
CalMac
Carbon bonnet
Post by CalMac »
Excellent condition - one tiny cosmetic crack (see photo)
I've fitted a set of Aerocatches (took about 4 hours!) as it is very light and quite flexible - I will provide the bolts for these. I fitted the bolts in two holes which were already there from factory so you don't need to drill any holes etc. Also included are 4 stainless bolts and penny washers to fit the bonnet to the hinges.
Only work required is two holes in the plastic panel which sits over the radiator - I'm happy to swap my plastic panel which has been drilled neatly for your undrilled panel if desired, saves us both some work :) You'll need to re-use your original washer jets and hoses - I filed the washer jet holes out to fit standard jets nice and tight.
Fitment is pretty good as you can see.
The only damage I could find was a TINY crack in the front/centre where you push down on the bonnet to latch (see photo 3 - it's about the size of an eyelash).
£280 CASH ON COLLECTION ONLY - this would get smashed to bits by a courier!
I paid £250 last year and then spent ages fitting the aerocatches so I've saved you some work :wink:
ashley
Re: [FINALIZED] Carbon bonnet
Post by ashley »
Is this full carbon, or fiber glass with a carbon skin?
CalMac
Post by CalMac »
Fibreglass with a skin I believe Ashley :thumleft:
jason256
Post by jason256 »
Where are you based?
CalMac
Post by CalMac »
Northampton
Feedback Bot
Post by Feedback Bot »
