Has anyone removed one camshaft at a time without removing the timing belt? I have seen this done before on other engines like Evo engines etc.
If I set up the timing to TDC and then cable tie the timing belt say in 3 or places to the cam pulley whilst keeping tension on the belt I should be able to take the cam bolt out from the pulley and proceed to remove that camshaft.
Then replace and tighten up before repeating on the second camshaft.
Has anyone done this before?.
Cheers Craig
