Quick one, does anyone know where to get at least one of the 6 half shaft connecting bolts from? And one of the little plates that go between the bolts? I lost a bolt which caused one of the little washer plate things
(technical name) to clip on my sump.
Reversed up the drive to see what it was to find out it'd only gone and put a hole in my sump and in turn dumped all of its 3 week old oil over the drive
Not exactly what i had in mind for a friday evening
I've found a replacement sump but now need the bolt and spacer.
Steve
