Hi all,
Since picking up the car, I have felt that the brake travel and performance hasn't been 100% despite all calipers having been refurbished and good condition discs and pads installed.
When depressing the brake pedal, the top
"portion" of the pedal travel has very little resistance before firming up and getting actual braking force.
I know the ABS models are known to have a slightly longer travel but I don't have the utmost confidence in the car's stopping power currently and I do have to put on quite a bit of pressure to stop from speed.
The car is a Rev3 with ABS.
I am using Mobil DOT4 brake fluid.
A friend and I have bled the system using the 2 person method
(tried engine on and engine off) and got a considerable amount of air out of the bleed nipples
(which I have also replaced as a test) but when no more air is coming out from any corner, there is still this dead/soft spot near the top.
When the engine is off, we can get the pedal really firm but as soon as the engine is on and the brake booster comes into effect.
soft/dead spot again!
Any ideas? I read somewhere that handbrake setup can cause this issue but the handbrake works flawlessly so I'm not quite sure if that would cause issues?
Thanks in advance dudes and dudettes
