Fensport dizzy caps
yhickfoeMR2
Fensport dizzy caps
Post by yhickfoeMR2 »
I need to get a new distributer cap for my Rev2 tubby. The cheapest place ive found is Fensport but they stock two types- which would I need? Im guessing the late 5mm one?
1. Distributor Cap - 3SGE & 3SGTE for Early 8mm Leads
2. Distributor Cap - 3SGE & 3SGTE for Late 5mm Leads
michael
Re: Fensport dizzy caps
Post by michael »
I believe they only supply pattern parts from Blueprint, you may find your local parts suppliers (Halfords etc) can get the same item for less.
yhickfoeMR2
michael wrote:I believe they only supply pattern parts from Blueprint, you may find your local parts suppliers (Halfords etc) can get the same item for less.
Oh so these arent the toyota ones then? I went to halfords today, they wanted £76 for a dizzy cap!!!
Is there anywhere else? Rogue systems do them for £40 but are they blueprints?
michael
Post by michael »
Give them a ring and check, last time I bought one from them it was a Blueprint item, they may have swapped to Toyota ones since then or another supplier.
Terry
Post by Terry »
I've got a brand new Copper Contact Dizzy cap and rotor arm if yer interested.
PM me.
Cheers Terry
iainh99
Post by iainh99 »
You could aslo give www.camskill.co.uk a try
yhickfoeMR2
iainh99 wrote:You could aslo give www.camskill.co.uk a try
They use Bluprint parts as well though, or are they as good as the real thing?
Terry
Post by Terry »
Terry wrote:I've got a brand new Copper Contact Dizzy cap and rotor arm if yer interested.
This is genuine MrT kit, modified by our own BenF.
Never been used, still in the box it was sent in. £50inc P&P if anyones interested.
