No it doesn't help, it's not what I asked for and your numbering is incorrect.
The article link I posted earlier shows the correct Toyota method for
numbering of the plug and the wire colours.
Numbering is
(looking at the front of the plug)
Top Left
= 1
Top right
= 2
Bottom Left
= 3
Bottom Middle
= 4
Bottom Right
= 5
Colours are
1= Green
[from/to drivers side switch]
2= Green
[motor]
3= Blue
[+12v from fuse]
4= Red
[motor]
5= Red/Blue
[from/to drivers switch]
Take the plug out of the passengers side switch and connect the meter across pins 1 and 5 of the plug
(not the switch) wire colours should be 1=Green and 5=red/blue
(there will be no voltage until you press the switch on the drivers side)
With the ignition on, hold the drivers side switch
(for the passengers window) in the down position and check the meter, should be reading 12v
(if you don't get 12v with the switch pressed then you don't have the meter connected correctly or your meter is set wrongly)
Repeat with the switch in the up position, it should also read 12v
(but opposite polarity) in your case I suspect
(and it's what I'm trying to confirm) you won't get any voltage in the up position.
