Hi everyone
I've had a stroke of luck and found myself a 88' MR2 T Bar 1.6
It's my first Toyota, and first RWD car, having owned nothing but Fords for the past 7 years, including a new Zetec S TDCi now.
I've attached a few pictures, so you can have a look.
But its in a rough state, and I'm hoping to do a nut and bolt rebuild of the entire thing.
I will start a project thread once I get it back here.
[ JUST realised I can't pop any pictures in until I've posted a bit more, so i'll add them later.
BUT as the title suggests, and as you can see the pictures, its been stood for around 3 years.
And to help to get it home, I need to remove the wheels and get some part worns on there, and try and start it
(doesn't need to happen, but it will make life easier)
What will be the procedure for starting up a 4A-GE that's been stood for so long?
So far I've got
(in no order)
- pop a bit of diesel in each cylinder
- pop a new battery in
- Hand crank it a few times to get the oil flowing
(any way of doing this easily? because I can already see it being a pain)
- Check the spark plugs
- Check for the fuel pump priming
- START.
