![Confused :?](./images/smilies/icon_confused.gif)
As title suggests if you turn the
If you release the key the dash and electrics come back, if you do this to many times the battery gets very low.
You can here I think the solenoid on the starter engaging or releasing when you release the key.
Tried putting car in gear and rocking it, in case the starter had seized but no joy?
Is there an earth strap that can cause probs or is it likely to be starter?
