My faulty alternator burned some wires in the loom of 1991 UK Rev 1
(??) 3S-GE so I changed the whole engine wiring looms
(including the passenger loom leading to it on 1993 rev2 UK and I took the 1993 ECU as well.
Now there's no ignition and I dont know why
I measured all ECU signals and they seemed to be fine apart of IGT signal
- it should show some low voltage once the engine is idling, but I cant measure it as the engine is not starting
(just cranking).
There is the 12V on ignition coil and all earths fine.
I got no idea why it doesn't start.
The alternator is disconnected
(as is damaged), lambda sensor is missing as the 1991 haven't had one and there is something missing just next to the fuse box.
The unplugged plug got 2 W-B and G-W wires as on the picture enclosed.
Can any of this prevent the engine from starting
My Jap version starts without alternator plug connected and there's also no any IGT signal when the engine is not running
(ignition ON)
- so I dont think that's the case.
I've been told the engine was running on the wiring and ECU.
I think that the engine inlet pipes was a bit thicker on the 1993 donor, but it got nothing to do with ignition
- maybe a bit with mixture, but it should start I think.
The old ECU got different ignition pinouts and variable resistor circuit so I'm not wondering why it's not firing on the old one.
Is anybody know what should go to the plug
?! It's cable is factory zipped to some small plate which was bolted to the engine bulkhead
- there was something on it in stock I think.
I think it was missing already when I took the stuff from the donor car.
The wires colors indicates stop light circuit, but I don't think that there's any stop light going into it.
I think the donor was manual car and the ECU says its manual, but it got some AUTOMATIC version pinouts.
http://imageshack.com/a/img921/6107/OkDSbS.jpg
[/img]
