alan wheeldon wrote:My advice is dont worry about it... it works dont it
But it's killing my clutch (if I drip it to reduce revs) and going through fuel !
black gts wrote:just a thought
is the butterfly fully closed. because i had taken the slack out of my throttle cable and when doing mataince on the car i moved the cable out of the clip its in and that had opened the butterfly , only a very small amount but it went upto 1900rpm
just incase mate
It's a completely different throttle body that is on there now.
So nothing to do with that either, plus Luke was on it so I'm sure he'd make sure that it's put on correctly
Cleaned up the ISCV properly as well, and checked that it was moving properly etc.
