I connected the sensor to the ECU and the engine now revs freely
It will be quite funny watching non Mr2 owners
Quick pics of the sensor/cable fitted.
I'm going to make a shield for this to prevent accidental throttle activating.
PW@Woodsport wrote:Time to crank this project up a little, it's already pretty cool but let's install a set of Evora clocks and get every warning light and gauge working as it would do in the Lotus.
http://url.photobucket.com/albums/v624/ ... uuzpve.jpg
PW@Woodsport wrote:Thanks!
So i've also installed an Aquamist FIA2 WI system as well, and set that to activate at 4psi, it's a neat setup that T's into the fuel injector signal, so copies the duty rate for the WI, not strictly needed on this engine but lowering intake temps is never a bad thing.
