The original failed readings were
Low idle
High idle
HC 193 ppm Above 200 is a Fail.
Lambda
I removed the Cat and it was broken, the element was loose and broken.
Can anyone advise on what my next move is, maybe the 2nd hand cat is also broken?
The car is driving fine and doesn't seem smokey or to be burning oil.
How do I check if the car is running too rich?
The previous owner replaced the Lambda sensor in the tiurbo Downpipe elbow.
Any tips would be appreciated here before it turns into a money pit.
