Right, time for a final season update.
A little later than planned, Ive been off in Iceland for a week doing this:
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpsetzodsyd.jpg)
Anyway, back to the Westfield.
Cadwell Park was the last sprint of the season, and allowing for the end-of season awards do the Toyota guys were holding it was being run on a Saturday.
Having already had a mid-week panic with the cracked manifold I was still feeling a bit disorganised and out-of-sorts when I headed up the M40, and a traffic-ridden 5-hour drive to the hotel didnt help much.
Still, it was a lovely clear night when I turned up so I had high hopes for a dry days racing.
I was woken up at 3am to the sound of rain crashing off the roof of the hotel lodge.
Bugrit.
So, off to Cadwell in the rain
we arrived fairly early but the paddock was already quite full, and unloading the trailer on the rain-soaked grass wasnt much fun.
I finally managed to get off and through to scrutineering, whereupon I measured 108dB on the noise test.
xxxx.
A bit of jiggery-pokery and we managed to get through with a barely-on-the-track-limit 105 and I was waved on my sheepish way, protesting cries of
Ill get a new exhaust! meeting stony-faced expressions from the Cadwell scrutineers.
Oops.
We finally headed out onto the sighting laps, my first time at Cadwell, and it was still soaking wet.
There was a lot of standing water along the start/finish straight, and even more along Park straight.
Plus there were a lot of leaves on the track through the woodland section.
My tyres? R888s that are almost on the wear limits.
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpsnauz1t57.jpg)
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpszskr13sj.jpg)
Fortunately I had actually done a bit of homework this time round and had spent a fair amount of time learning the track on YouTube, and of course everyone else was in the same boat
(almost literally!) as me.
My first two runs I managed to keep pretty tidy, and when the timing sheets came out I was very surprised to see I was leading my class
ahead of a Duratec-powered Westfield and a Caterham on wets.
My confidence started to build
(despite aquaplaning at 100mph down Park a couple of times!) as the track started to dry, but this meant the more powerful Duratec car could get his power down and he ended up knocking a couple of seconds off my time which I couldnt claw back.
Still, I was happy with steady improvements in my times until the rain started again mid-afternoon, at which point I knew I couldnt beat my best time of 1:50.45.
My last two runs of the day were me taking the opportunity to explore the limits of the car in the wet a bit more
leading to a void run after over-steering over the kerb at Mansfield, and then on my final run carrying too much speed through the Gooseneck and cutting off the apex
Still, youre not trying hard enough until you fall off, eh?
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpslyrl9lml.jpg)
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpsuply1rea.jpg)
I ended up runner up in my class but down in 11th overall
not my best result but given that the Westy struggles to get over 100mph on track
(@ almost 7,000rpm in 4th) I tend to be less competitive on fast tracks.
I was also very chuffed to be awarded overall class runner-up for the season as well
![Image](http://i429.photobucket.com/albums/qq14/benedwards64/temporary_zpsgkyxd7f5.jpg)
So thats it for sprinting until March
(probably, depending on Javelins calendar next year).
Ive enormously enjoyed my first foray into competitive motorsport and will definitely be running in the series next year.
Ive got a few bits to keep me busy over winter though
after cracking the manifold and, apparently, blowing all of the baffles out of the silencer its time to invest in a new system.
It has always been a bit noisy
(apparently you could hear me going round Cadwell from the main road
) and it has got steadily worse this year, so ideally Ill be after a system that will see it comfortably under 100dB.
On top of that I need to experiment with raising the gearing a bit
the 13 track wheels I have are currently running 185/60/13 R888s all round and one pair are pretty low, so I might try a pair of 205/60/13s on the rear to raise the gearing slightly
(this would match the overall diameter of my road wheels, so Ill try these on a track-day and see if an extra 5-10mph at the top end is enough).
On the other hand I think my diff could do with a rebuild, so it may be worth biting the bullet and getting it rebuild with a different final drive.
Some head-scratching to do there I think.
Other than that it will get some routine servicing and another alignment check to make sure everythings in order, and hopefully well have some nice sunny winter days so I can get it out and about!
