Toyota OEM pads?
Ginjaninja92
Toyota OEM pads?
Post by Ginjaninja92 »
Replacing the front discs and pads this week, going with Toyota discs and priced up Toyota pads too.
The front pads come in at £56, so the question is, should I get them or get EBC, or Carbotech, or something else?
I know it's been covered many times before so apologies, I can't get Porterfields as I need to change them this week so they're out the question. What would be the second best pad behind them for fast road/daily use?
Thaaaaaanks
Re: Toyota OEM pads?
I have Carbotechs on mine and Motul RBF600 fluid. Awesome pads! :thumleft:
Ginjaninja92
Is that XP8's? I hear they're quite squeaky and dusty? Thanks for the info man!
Ginjaninja92 wrote:Is that XP8's? I hear they're quite squeaky and dusty? Thanks for the info man!
Yes, I believe they're XP8s. Would need to check that. And yes, they are squeaky and dusty, but they stop, and they stop well! :thumleft:
Nic
Post by Nic »
OEM pads are very good on the road, they work well from cold, give good bite and no noise (even without anti squeal shims fitted). I'm running freshly overhauled stock calipers, OEM pads (without shims), braided lines, Motul RBF600 fluid and a Cusco brake master cylinder stopper, the pedal feel is very firm and the brakes will easily stop the car on it's nose from silly speeds.
I wouldn't touch any pads made by EBC.
Nic
[email protected]
MR2 Rev 3 GT Turbo
2mad
Post by 2mad »
xp6's for the street .. thats what i had and they were amazing =P~
They bite hard cold and bite hard mega hot .. perfect for the street :thumleft:
Xp8 could lose you performance on the street they need to be much hotter to be effective .. more of a semi track pad iirr 8-[
Race Idiot
Post by Race Idiot »
Honestly the oem pads are pretty damn good for most cars on the street.
I like the carbotechs but i'm gonna look for an alternative on the street because the amount of dust they generate is ridiculous.
tempted to get a set of porterfield r4-s and just swap the xp8's back on for trackdays
2mad
Post by 2mad »
Yeah carbotech and dust .. ow boy ](*,)
The dust is worth it. For me anyways. 8)
Obviously they're not for everyone.
Nothing wrong with OEM pads. I had them on my car for years before changing to Carbotech.
2mad
Post by 2mad »
RedMR² wrote:The dust is worth it. For me anyways, uprated brake fluid, carbotech pads and the Pyrenees. 8)
The stopping power i had .. didnt care about dust :thumleft:
markstevieandmads
Post by markstevieandmads »
I've got carbotechs xp8s.
Yes they are very dusty....
Yes they are very squeaky.....
Yes they can be expensive.....
But they are bloody awesome!!!
Cold are brilliant but hot are even better.
I drive all manor of cars old and new and the brakes on my turbo are the best I have come across in over 18yrs plus of driving.
2mad
Post by 2mad »
markstevieandmads wrote:I've got carbotechs xp8s.
Had xp6's and they did the above .. carbotech , for the driver .. trust me :thumleft:
Correction, my Carbotech pads are Panther Plus. Just checked.
2mad
Post by 2mad »
I think thats what xp6's used to be cauld .. great pads , perfect for the street :thumleft:
2mad wrote: great pads , perfect for the street :thumleft:
Oh, I know. Done the Le Mans trip with them on, twice. Fantastic pads :D
MR2 Rich
Post by MR2 Rich »
With the Carbotechs do they generate more heat than standard pads? Are they more likely to warp discs?
No 2 :(
Ginjaninja92
Loads of great responses in here!
Thanks very much for sharing your experience, I'll get the OEM pads from my man at Toyota and look into the XP6/8's for my next change, anyone have experience of the Carbotech versus the Porterfield item?
Again, apologies for covering old ground but people always seem happy to talk about their experience with different brakes.
Thanks again
kirk
Post by kirk »
What's the best place to pick up Carbotech pads?
kirk wrote:What's the best place to pick up Carbotech pads?
Think Rogue Motorsport supply them. They're about £300 for a set.
Torero
Post by Torero »
Nic wrote:I wouldn't touch any pads made by EBC.
Interesting, as it's not the first time I've heard this. I've run Red stuff all round (which I preferred) and now I have yellowstuff all round with a Wilwood Big Brake kit upfront, master cylinder stopper and HEL braided lines on all corners and they are fine.
There again, I get a little brake travel despite the system being vacuum bled but that's nothing to do with the pads which is why I can't be more committed Yellowstuff. I may just take the plunge when these need replacing so I can be a bit more objective and try OEM or XP6/Panther plus or better still Porterfields just to see the difference.
3VZ-FE V6 TRD Widebody Replica
Draven wrote "TRD dude. TRD... Can see awesomness from anywhere. "
