hi, how easy is it to remove the rear window? does it need to be cut out? as in the rubber seals will need to be replaced? thanks in advance.
T
rear window removal
Re: rear window removal
It will push out from the inside , start from one of the top corners and work your way round . You can still use the original seal when you re fit
Thanks mate...do you know if that seal can be brought separately?
Getting some work done to the car the window need to come out...but scared they may break it.
T
T
I've removed a few, they are actually quite easy to remove, harder to put back in mind, use the string method, every time I've put one back in (twice) the seals are fine , this may be because they are pretty robust or how careful you are removing them.
cool, thanks for the replies guys. Would there be a guide on here...I'm just looking. Cars going in for a respray so want to arm them with help in case they need it.
