Boost pressure stuck
Post by Martin F »
My boost pressure seems to be stuck between 1.34 and 1.41 bar of boost.
neither high or low boost makes a difference, i even turned the boost controller off :?
I then fitted my other controller and exactly the same happens, anybody have any idea where to start looking ?
Could it have something to do with the spring in the external wastegate ? i would imagine one of these to be pretty bullet proof though....
cheers :thumleft:
Peter Gidden
Re: Boost pressure stuck
Post by Peter Gidden »
Start by unplumbing the boost solenoid (not just disconnecting it).
Post by Martin F »
Peter Gidden - SBITS wrote:Start by unplumbing the boost solenoid (not just disconnecting it).
i should have thought of that, will give it a go tomorrow, cheers Pete :thumleft:
Post by Martin F »
OK, first i found a boost vacuum pipe not attached to anything, (this will be why my boost controller is under reading.)
Secondly i found that the top bolt for the tial external wastegate has worked itself loose and is missing... :shock:
Anybody know where i can get another bolt from, i don't even know what thread it is, obviously is has a hole inside it for the air pressure....
any help with getting the correct bolt would be great :thumleft:
Post by Martin F »
Found this, bit much for a bolt, anybody know the thread size etc. as i can buy locally or online for a much more reasonable price
http://www.turbodynamics.co.uk/shop/10m ... 1fa007529b
*edit* Just decided to bite the bullet and buy the above, on checkout they wanted £6.37 plus vat for posting a bolt, so defo not buying it from them :(
will maybe take the other one off this weekend and go to a local bolts place :-k
Slarty
Post by Slarty »
From the (albeit tiny photo) it looks like a 10mm banjo bolt? A local hardware place etc isn't likely to stock them.
A quick google brings this up:
http://www.ebay.co.uk/itm/like/37127915 ... 0&ff14=108
As said though, that's only if it's a banjo bolt, and of the correct size (thread diameter) and pitch (distance between the thread peaks).
ashley
Post by ashley »
The tial banjo bolts are M10 x 1.0mm thread, 22mm long measured from the end of the bolt to the underside of the head. The central orifice is ~6.3mm diameter.
HTH :thumleft:
Peter Gidden
Martin wrote:Anybody know where i can get another bolt from, i don't even know what thread it is, obviously is has a hole inside it for the air pressure....
I keep them in stock... :whistle:
Post by Martin F »
Ohhh, can i get one please, i will pm you :thumleft:
A few days after posting this it dawned on me that i had another turbo kit sitting in the house so i pinched the banjo bolt from that :oops: , better replace it :eye:
