I'm planning to have new shocks, springs and bushes fitted to my SC as soon as I can.
Regarding the bushes though, they said it wouldn't make much of a difference
So my questions are:
Is it better/worse to do the shocks and springs before/after the bushes or should they all be done at the same time?
Is it likely I'll need new top mounts?
Should the bush at the top of the strut be changed for a poly one?
Do poly bush kits come with a tool to help fit them?
Thanks for any light you can shed on the matter!
Andrew
