Noble M500 Upgrades & Overhaul
gnzyza
Re: Noble M500 Upgrades & Overhaul
Post by gnzyza »
That factory wiring is a joke, certain hand crafted...by a monkey
outrun
Post by outrun »
I have just sat and read through all of this, Peter.
Very impressive machine and ideas.
thomp1983 wrote:although it looks untidy the use of insulated crimp terminals is widely accepted in applications where vibration is a factor as they don't fracture the way soldered joints can when subjected to vibration, there still used for some jobs in aerospace and electricians can use them to join cables too but sadly they do just look like a bodge
Very much this.
No matter how suited to the application, those coloured crimps will always look wrong, though.
DB Mr2
Post by DB Mr2 »
Amazing insight, keep up the good work Peter love reading this thread.
JD
Post by JD »
Fascinating thread and I'm guessing a good showcase of Peter's mad skillz.
There's a Noble feature up on SH today: http://www.speedhunters.com/2014/10/bre ... ass-noble/
synXero
Post by synXero »
JD wrote:Fascinating thread and I'm guessing a good showcase of Peter's mad skillz.
Enjoyed reading that.
Massive part of me wants a Noble.
Until I tell you it's £3000 for a clutch change. :mrgreen:
Peter Gidden
Post by Peter Gidden »
Whilst printer is test pringting the carbon fibre offcut, rewire has started.
First batch of Deutsch plugs arrived:
Started with heater control plug:
Next was first of two plugs for the Dash2. I've designed the new loom so one plug interfaces with the main dash loom, the other with the data logger and auxillary sensor inputs. Engine parameers will be inputted via CAN direct from the ECU.
So first plug finished, and test:
For a change of scenery i spent an evening in my cellar on the lathe. Made some spacers for the latching relay boards.
Perfect fit!
Back to loom wiring later this week...
gerbil1028
Post by gerbil1028 »
Nice work Pete . Didnt know u played on lathes.
Any Insight into the low oil pressure. ?
One day the Phoenix will rise from the ashes.
Peter Gidden
gerbil1028 wrote:Nice work Pete . Didnt know u played on lathes.
Did my degree in mechanical engineering with the MOD. 8)
gerbil1028 wrote:Any Insight into the low oil pressure. ?
Not looking at the engine 'til dash finished.
Peter Gidden
Well it's been a very busy 3 months. This dash project has turned out to be a lot bigger project than i predicted. But it's almost at the stage of refitting.
So, first update. I'd already modified the original dash to convert the 2 humps for the speedo and tacho to one hump for the Dash2, and mounted the Dash2 onto the dash face:
However, what i really wanted was to set the Dash2 into the dash, and i knew i wouldn't be happy unless it was done.
So, first i made a silicone plug of the Dash2, then made another a little larger all round:
Then took a grp mould of the plug, and took a mould of that. Tidied the shape up:
Then took a mould of that:
Then marked up on the dash where the panel was to go, and carefully cut a hole. Using quick set epoxy adhesive, glued the panel into position ready for bonding in:
Flipped the dash over, and from behind, fully bonded the two panels together. Then took it round to Dave at DEeepcar Autobidies, for filling, flatting and priming. Et voila:
Next update will be the centre panel...
slipping clutch
Post by slipping clutch »
Some top quality work there Peter :clap:
ashley
Post by ashley »
ashley wrote:it looks ok I guess
:mrgreen:
I get inundated with all these progress pics by picture messages!
Top effort as always Pete, great skills on show.
Now, get my bloody car finished! :mrgreen:
Peter Gidden
Back to the centre panel.
This is how it looked after Reverie had routed the holes according to my plans:
I then contacted a client of Carol's who has a couple of these:
State of the art, £35K digital printers. 8)
He test printed onto the scrap carbon from cutting out the hole for the Garmin. That piece was then sent to Reverie for lacquering to ensure there was no reaction between the digital printing ink and the epoxy lacquer. All worked out well.
Met up with Glenn after work one evening. Chose a font to match the engine start button, lots of size and quality image editing, and lots of test printing.
At the end of the evening we had this:
Panel text printed, buttons printed and both logos at bottom of panel printed.
Panel was then sent back to Reverie for lacquering and bonding of the previously prepared Garmin bezel.
2 weeks later i had this:
ashley
Post by ashley »
Flash git :mrgreen:
Very nice indeed- proper job :thumleft:
Peter Gidden
The 4 circuit switches were a special order from Canada and were going to be on a 6-8 week lead time, so i set about the next project - A TPMS.
Those that have seen my Group Buy know that i wanted a compact system, ideally in a gauge, but Stack's system was out of the question at £2400.
So i chose this:
Perfect - small, well very small, temps and pressures, and good looking.
But i wondered ... how small? Hmmmmm ... Would it fit? ... Could i make it fit? So, out with the Dremel. And i cut open the case to reveal this:
Next problem was those two SMD push button switches at the bottom of the pcb. So out with the magnifying glass and soldering iron. I desoldered the switches and soldered on jumper wires, and as the solder pads are so small, i epoxy'ed the wires to the pcb so save them getting pulled apart. Jumper wires are 6" long and terminate in a ON-OFF-ON momentary switch to imitate the original push button switches.
Next i got on to Reverie, and had them custom route me a circular disc out of 0.8mm prepreg carbon with hole in the middle exactly same as the original casing. Light, strong and thin.
Then i had the disc painted to match Noble OEM gauges.
Then a call to Glenn at InstantPrint who printed my dash. If it was going to match the Noble boost gauge which i'm keeping in the car, i'd need the Noble logo printing on the face. After a few hours work late one evening, i had this:
Looks pretty good match to me:
Carefully slid the pcb into the housing, and all the time spent measuring paid off:
I have a TPMS in a gauge!!! 8) :D
Final job. In the event of an alarm, either of the push buttons needs to be pressed to reset. So i soldered an additional pair of wires to one pair of the jumpers, and made another trip back to Glenn:
MR2 Turbo Boy
Post by MR2 Turbo Boy »
Fantastic workmanship, Pete... :thumleft:
MR2 Turbo Boy
Ever thought about setting a Dash2 into a dash of a MR2..... :whistle:
Peter Gidden
MR2 Turbo Boy wrote:Ever thought about setting a Dash2 into a dash of a MR2..... :whistle:
I dare say that could be arranged......
synXero
Post by synXero »
I really like the oem look gauge. Good job.
