My g/fs rev 5 N/A UK spec MR2 has been difficult to start since the weather started getting colder.
I've ordered a set of NGK BKR6EIX as I'm not sure what plugs it currently has in there.
What are the next things I should be looking at?
Thanks!
mrturbotom wrote:I'd be looking at a coolant temp sensor and intake temp sensor
Mullen wrote:CTS is the green sensor round the back/underneath the throttle body.
You'll need a deep 19mm socket to get at it.
They're£14 ish from Camskill
- I replaced mine recently and the old one crumbled to dust as it came out, so might be worth replacing it regardless just to be sure.
