Is this one of your race car builds?
3SFE upgraded to 3SGTE
Re: 3SFE upgraded to 3SGTE
I'm a moron eh?
Ok whatever, at least i tried to help you and didn't resort to name calling.
I'd say you have a life expectancy of around a fortnight here with that great attitude you have.
Good luck with your 89mm pistons in your 3s-fe block
Like I said you can't read!
As I have already said I have more than 1 car and that I am not going to bother changing the 3sfe engine just fix it as everyone has advised against it!
My other car is a turbo and already has alot of upgrades and was talking of doing these upgrades to this engine.
Also nowhere does it say how long I have owned MR2's and for your information its a few years.
Maybe if you tried reading previous posts you might not get called a moron!
MrSpleen wrote: this is the first I've heard about the block being substantially heavier on the 503e/ 3SGT and it may explain why so many people here are saying its not possible in which case I may have to stick with standard bore but may be worth doing some measuring once I get engine apart, as for the turbo I'm looking at GT3582 once engine is built and it should fit nicely with around 20-25lbs of boost, as for the current setup fuel rails, injectors, intercooler, dump valve, waste gate, ecu and intake have all been uprated already so its engine internals and turbo that needs doing next and I'd rather sort internals before changing turbo. I will probably change the inlet manifold as the non turbo manifold actually has better airflow and doesn't make the engine run lean on cylinder 3 and will give better performance.
Yep- the general consensus based on the collective experience is to keep pistons as close to 86mm as possible. On the earlier engines (rev 1 & 2) the blocks seem to crack around the water pump housing, on the later blocks they seem to crack in cylinder, or on the deck between 2 & 3.
It may largely be tuning based (retarded ignition) that causes the damage, but it does appear that there is an underlying weakness in the blocks.
I did note that the 503e ran 7.0:1 compression, maybe another reason why they managed to run with a potentially weak block? This would allow plenty of advance...
Agreed on not using the stock turbo manifold, not convinced the NA setup is your best alternative though- the plenum volume is not ideal, nor the length of the runners. Have a look at "RacerX Fabrication"- Jeff will build you a tuned manifold with tapered runners to your own specifications, and will certainly help you pull the extra power that you are looking for.
Have you looked at Forced Performance (HTA) turbos, or the Garratt GTX series? Might be worth a look...
Good luck!
Always late to the party lol ... love a good project me .. please listen to the advice given , its tried and tested ... hope you weren't trolling us ... looking forward to pics
What type of race car do you work on .. do you build engines ?
Anyhoo , good luck .... and ... pics please
Oh i can read alright, especially good at doing so between the lines, also my bullshitometer is banging hard into the red.
I am just about to finish off an Austin Healey Sprite for my customer and have already built him a hill climb mini and helped him with his Austin Healey 100/4 I also did some work on his Porsche Boxster and his Ford GT40 so apart from the Boxster most of the stuff I work on is a lot older than my MR2 obviously this is just the cars I've worked on recently for him. Still some nice cars and the cheapest there would be the Boxster and its probably worth more than all my cars lol
Anyone able to tell me how to post pics from my facebook page?
Just upload them to Photobucket mate
https://scontent-b-lhr.xx.fbcdn.net/hph ... e=553364C6
https://scontent-b-lhr.xx.fbcdn.net/hph ... e=55430495
https://fbcdn-sphotos-b-a.akamaihd.net/ ... 934b262a2c
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 902ff9fcc2
https://fbcdn-sphotos-c-a.akamaihd.net/ ... 2753ac987c
Link your facebook page unless its you personal page .
You should be able to link pictures from it though
Thanks for reposting them Ashley I'll have to sort a photobucket account
- IMOC Moderator
You used to be able to copy image urls from facebook but that no longer works, frustratingly you HAVE to use photobucket or something similar
Yer now I'm trying to figure out how in photobucket ffs lol
Lets see if this works
[url]http://i1379.photobucket.com/albums/ah1 ... 96254d.jpg[/url]
nope I hate forums!!!!!!!!!!
ha to slow ashley
OK how?
I'll just put in URL's and you can repost ty
http://i1379.photobucket.com/albums/ah1 ... 383062.jpg
http://i1379.photobucket.com/albums/ah1 ... 015a31.jpg
http://i1379.photobucket.com/albums/ah1 ... c48dad.jpg
http://i1379.photobucket.com/albums/ah1 ... 169ea8.jpg
http://i1379.photobucket.com/albums/ah1 ... edef5b.jpg
http://i1379.photobucket.com/albums/ah1 ... edf717.jpg
http://i1379.photobucket.com/albums/ah1 ... 192e53.jpg
Well theres the cars, even if I can't figure out how to post them lol, that I've worked on recently including my MR2's and my old V8 Camaro
pistol pete wrote:ha to slow ashley
Post edited due to me being an idiot when it comes to forums!
