[Mk2] [Turbo] ahh how to remove engine heat shield?
steve07
Post by steve07 »
Can anyone tell me how many nuts there are and where they are to get the engine heat shield off?
i got four off but still couldnt remove it?
cheers
steve
C35Rob
Re: [Mk2] [Turbo] ahh how to remove engine heat shield?
Post by C35Rob »
which heat sheild? the bulkhead ones or the exhaust manifold?
the exhaust manifold and turbo ones are easy.
the bulkhead one is more difficult, there's 3 (i think) bolts in the small one which comes off easily then there's 3 or so in the big one - the big one can be removed with the turbo in place but you'll need to remove the inlet pipe from the turbo, pull the heat shield up vertically and towards the passenger side of the car, give it a good tug and wiggle and it'll come out - they get caught on the shifter cable bracket.
steve07
Post by steve07 »
I got off the turbo one which is held on wih x3 bolts, but im stuggling with the one on the back of the engine held on with nuts, i got four off but it still werent bugging.
