androo007 wrote:Perfect!!
So is it easy to change over? Any drilling, wiring or whatnot needed?
Just face off and plug in?
You'll need to extend the wires for the boost gauge which is obviously a piece of p1$$.
Taking the lens off the gauge is easy, just a tiny screwdriver and pry around the edges, you'll see what i mean once you have it.
There is a small issue with the wee light tunnels for the indicators, you kinda need to break these a wee bit
(to get the new gauge to fit) so your indicator dash light now shows as green.
these wee tunnels keep the light from other areas out so your indicator dash light appears as black, with these broken the light gets into them.
I coloured mine in with black marker
